Case 530 PTO clutch
Mark Shurvin
I have a Case 530 and the PTO clutch seems to be slipping under load. This is the model with the long handle to the right and rear of the seat which is pushed back to engage. I've followed some adjustment instructions posted on this site from a Case Manual but can't seem to locate the "spring loaded lock pin" that's supposed to allow adjustment. Any suggestions?
A spring loaded lock pin sounds like a pin inside on a the pto clutch.
On a 930 you took a cover off and you could see the clutch inside. You might have to rotate the engine some to see the pin depending on where it stopped.
This is the best I can do at the moment.
RT (my 2 cents worth)
