bookworm007
Alright I know better but I am a sucker for a project. I found what looks to be a late 60's gas powered Case 530ck backhoe for $800 or basically scrap value. The current owner was going to restore it, but parked it 15 years ago and hasn't touched it since. As typical owner doesn't have a ton of info and only one picture. It is local to me so I am going to go look at it in person this weekend. From what you can see in the picture things look somewhat promising. It is located in eastern Washington which is a bit more of a forgiving climate. It was stored with most hydraulic cylinders completely retracted, coffee can over the exhaust, and while I'm sure many of the hydraulic lines need replacing they appear to still have all the factory hose mounts. All the other backhoes of this vintage I have seen are zip tied and duct taped to oblivion. While I do not have a ton of experience with hydraulics I have rebuilt a number of engines, and do a lot of automotive mechanic work, so 1960's tractor tech doesn't seem too crazy. My first priorities are to verify that the engine isn't locked up, brakes aren't frozen, and that water hasn't flooded the trans, hydraulics, or engine. I am going into this with the expectation of needing to do a full tune up in addition to rehabbing the cooling system and fuel system, change all fluids, and likely repack/replace all cylinders and hoses. All this with the goal of having a backhoe to do little projects on my property like ditches and leveling out some bumps.
Now the Questions:
According to the Case manual with buckets, the tractor, loader, and backhoe this thing should weigh in the neighborhood of 9000 lbs more if it has weighted tires and is full fuel. Is this correct? I tried to google this but a bunch of folks start citing weights from later alphabet series 580 machines which are much heavier than the 530 series.
Any other major items that need to be checked to confirm viability due to difficulty to repair or rarity of parts? Clutch, Trans, Shuttle Shift Mechanism?
Finally is this reasonable? Or should I run and run fast? I wish I knew why it got parked 15 years ago, fellow says it ran when parked but its also on a farm with a bunch of old equipment so maybe they got a newer toy?
Anyways I appreciate any and all advice!
Now the Questions:
