Case 530CK wont move
Jhalden
HI, have a 1965 Case 530Ck that wont move. I have taken off and dissembled and cleaned the Torque Converter control valve (valve clutch petal hooks to) as it was sticking. All moving freely now and there is one washer on pressure reg spring. I also removed the valve beside it (not sure what called but can measure converter pressure at it) and cleaned.
-oil pump pressure as measured at filter is 160, this is at the low end of range 160-235.
-Clutch pressure as measure at T fitting is 0 with clutch out and 25psi with clutch pedal in.
-unhooked hose from cooler going into T filling at control valve and put in bucket, seems to be lots of oil flow.
Any ideas? Guessing bigger problems?
(quoted from post at 13:54:12 07/28/19) HI, have a 1965 Case 530Ck that wont move. I have taken off and dissembled and cleaned the Torque Converter control valve (valve clutch petal hooks to) as it was sticking. All moving freely now and there is one washer on pressure reg spring. I also removed the valve beside it (not sure what called but can measure converter pressure at it) and cleaned.
new to these forums. Who is the expert on the case-o-matic around here? Maybe can contact directly in a PM. Decided to shim reg spring a bit with a couple of washers and pressure is now 50pis. My pressure is on low side out of pump measuring at filter 160 so wondering if relief valve at pump is faulty, or does it ether work or not at all? Just trying to get some advice before rip into this further so not blind. thanks
just bumping this post up. Anyone with good experience on this subject? thanks
