Robert1234
can anyone give me a picture and stats on a case 530ck tractor endloader. weight, type of motor oil and type of hydraulic fluid have seen tractor from distance , 4 speed? 3 point hitch?
There may be some info here that may apply to the tractor you are looking at. https://www.casece.com/emea/en-me/resources/prior-models. Tractordata is another source of some info.
As far as motor oil and hydraulic fluid there are always several options people may use. To be certain of transmission and 3 point hitch you need to look at the tractor. I think a 4 speed with dual range shuttle was common for the transmission. 3 point hitch would have been an option, again you need to look and see if the tractor has it. I take it this is a tractor you are looking to buy. You should check what the transmission is and see if it has 3 point hitch before you purchase it. If you are looking for 3 point hitch you may want to see if has a PTO as well. You should ask if the owner has manuals to go with it as part of the sale.
