Liquid_wrench
Location
Ohio
Cant find the correct manual for this machine. Does
anybody know if theres a filter for the transmission? It
has the 8 speed so it takes trans hydraulic hi tran fluid.
There is no shuffle lever on the steering wheel and no
filter in front of radiator, only the pump. When I drain
the transmission fluid can I drain the torque converter
too? I think someone put the wrong fluid in it maybe.
Had foam on dip stick.
Thank you for your help.
Attaching the manual pages.
Filter should be in front of the radiator, driver side. Cast housing with top, 4 bolts. WIX Filter 51518.
Yes the TC can be drained. Has to be manually turned until aligned with hole. Advise you to take a piece of cereal box cardboard and roll into a tube and stick into hole so drainplug does not get into the case.
he is right about those plugs falling into the housing. i had to fish 1 out of a friends 411b. it was the back plug,not as much room to go far and not much room in there
