Case 580 CK
Larry806
580CK Sn 8328527 , Motor Model G188D , Sn 2638546
I rebuilt the motor and installed a new radiator it runs great . Just got it out of the shop , only has less than a hour of run time . Yesterday it started running oil out the blow by tube . Shut it off and checked the oil . The motor is full of hy. oil . I think it must be getting in the motor from the shuttle shift ? I don"t see any way the Hy. oil from the loader or hoe could get in the motor ? Is there any common problem that caused this ? I"m thinking it might be at the back of the oil pan where the gasket"s go between the shuttle oil & engine oil ? Everything looked good and I thought sealed good ? Just looking for idea"s before I tear it down again . Thank you for any help !
Has the shuttle transmission oil level dropped? If so there is a seal in the flywheel that may have failed.
