Case 580 Super L Backhoe - Transmission problems
scoutring
I have a 580 Super L, My problem is after I run it for about 10 minutes, it stops moving. The emergency brake lite is on. If I wait about 10 minutes, it starts working again. I unplugged relay #one and the lite goes out. it runs for about 15 minutes and the same thing still happens. I spent hours trying to find anything about the problem in the manual, but could not find anything about it. I've checked the brake linkage and emergency cable, and found no problems.
Any help would be apricated.
Should have put this in my other reply. There is also a
JI Case topic section here on YT. I have seen some
Case TLB questions answered there, see link. There is
also a Crawler and Backhoe section here, fairly low
viewing traffic there. Let me know if you cannot figure
out how to get to it.
J.I. Case topic section.
If you disconnect the wire on the declutch solenoid and the problem goes away you know the problem is either the button on the loader control, the
solenoid or the wiring. Worth a try.
(quoted from post at 00:17:30 11/03/22) If you disconnect the wire on the declutch solenoid and the problem goes away you know the problem is either the button on the loader control, the
I already tried disconnecting the switch, and the backhoe still stops after about 10 to 15 minutes. If I stop and wait, it will start working again.
(quoted from post at 17:25:36 11/02/22) Should have put this in my other reply. There is also a
Thanks I'll check it out.
