I just recently acquired a 580 case backhoe tractor, and the previous owner removed the injectors to get them tested. I usually deal with the older cases, so does anybody have any tips or tricks for replacing them? Thanks
Your question was not too clear. any letters behind 580? Are the injectors out now? are you going to remove them? With more information I may be able to help.
It is a 580 CKB and the serial number is 8704987, the guy took the injectors out and now I need to put them back in. He said they tested out good
take your 22 cal. rifle brush. clean hole make sure the white seal is on the injector, lube injector and push it in. bolt clamp to cyl. head.
