Doug In NJ
I changed engines (188 Diesel) in my 580B backhoe and need help with the starter motor. I was trying to start the machine for the first time and the starter motor made a serious clunk of a sound after turning over the engine for a few minutes. I pulled the starter out and found the casting around the starter motor gear that engages the flywheel sheared entirely off. In addition, the starter gear showed a lot of wear and stress. Is it possible I have the wrong starter for that machine. i.e. the gear on the starter motor is not compatible with the gearing on the flywheel? The number of teeth on the gear of the starter is 10. In fact, all three starters I have have the same number of teeth10. Any ideas?
