Case 630 PTO
lj607
I recently bought a Case 630 COM. When I got it the PTO didn't stop turning after using it for a while with nothing on the PTO it quit completely. PTO turns free by hand but doesn't engage at all. I don't know anything about these transmissions. Wondering if folks think its the PTO clutch or if there is something deeper that might be bad?
On that model the pto brake is adjusted by the spring pressure on the linkage,, clutch adjustment is done through a 3/4" pipe plug on the LH side of the pto housing as seen in the pics,, I will dig out a book showing the adjustment steps in a bit
cnt
pto brake adjustment
pto clutch adjustment access plug
Sounds to me like the lock out pin is disengaged. Maybe. Look in the 10 O Clock position, using the shaft as the center, and look for a 3/8" pin. Shifts in & out. Can't remember which position engages.
you mean the pto shaft kick out rod John? when you kick that out the shaft does not ever turn with engine running,, maybe I misunderstood the poster
cnt
Case Nutty thanks for the pics. I didn't know the plug was any more than a drain. It feels like it is locking in when you pull the lever but nothing happens.
OK like John said on top of the housing to the left side is a rod with a screw in it with a hex head,, if that is all the way forward it is in pto kick out mode, take a bar and pry the shaft tot he rear you may have to turn the pto shaft a bit to get the gears to mesh,, it will lock out when engaged if it is indeed pushed in if you need I can take a pic of that also
That took some looking to find since it was buried in years of chafe and so on but we got it. It doesn't look like it has moved, the screw is out about 1/4" from the housing
I got it. Thanks. I put up a reply and a pic but it seems like my posts are showing up out of order
