Case 631C-H
dwh9950
I am looking at 631C-H, it is a diesel, with the Case-o-matic drive and dual range transmission. When I push down on clutch pedal there feels like there is nothing there and the clutch pressure gauge drops down to low. Am I doing something wrong or? Any help would be great!!
Put this down on the Case forum. Also, for goodness sakes spend the $40-50 dollars on both the 630 operators manual and the COM (Case-omatic) service manual.
Sounds like it's working fine. There is no
clutch in those as they are a torque
converter system. Think of them like an
automatic transmission in a car, put it in
gear, drop the clutch and add gas to go.
Letting the clutch out above idle is the
same as dropping your car in drive at that
throttle setting. Always let the clutch
out at idle then add gas to move.
