CASE 730 CK 3 POINT
46NADER
LOOKING FOR DIRECTION ON A 730 CK. 3 POINT ARMS WILL GO DOWN 1/2 WAY AND STOP "HARD".. LOAD/DEPTH SETTINGS MADE NO DIFFERENCE.. IT RAISES FINE AND CANCELS AT ANY PLACE YOU STOP LEVER AT.. JUST NOT HITTING THE BOTTOM.. MOST LIKELY IN DOM VALVE?? OR INTERNAL LINKAGES??
JUST BOUGHT THIS TRACTOR.. THANKS
They should go down lower than the drawbar by a couple in inches
but not all the way to touch the ground ,,. that established ,you
may have Draft o matic valve acting up. Usually they are absolutely
NO GO ,your problem is out of character ... i would look real hard
at every possible mechanical stop ,,a bolt head , ? a bar of steel
(quoted from post at 18:24:29 08/13/19) They should go down lower than the drawbar by a couple in inches
THANKS FOR THE RESPONSE olgentdc , LOOKED CLOSER AND FOUND THE PROBLEM.. GUY BEFORE ME CHANGED HYD HOSES FROM VALVES TO OUTLETS. HE HAD 6" OF "ADAPTORS AT VALVE END THAT EXTENDED PAST UPPER DOM ARMS.. ARM CAME DOWN TO FITTINGS AND STOPPED ON TOP OF THEM.. GOOD THING I DIDNT USE THE SKIDDY TO TRY TO PUSH THEM DOWN FURTHER!!! THANKS AGAIN..
