Case 730 Fuel system
TrevorB
Hi I have posted other questions before about this tractor and everyone on here was very great help. Today we have fully assembled my case 730, but we are having an issue getting fuel to the 3rd fuel filter. Fuel come out of the tank then it goes into the 2 main filters that are together than the fuel line goes up to a another filter (i believe thats what it is) then it goes in to the fuel pump. but we cant get fuel to that filter. I have heard of some case tractors with a manual hand pump but mine diesnt have one. Any suggestions?
Thanks,
Trevor
first off depending on the serial# of your 730 there are different ways to bleed the system, first the fuel tank must be Full, if you have a later "CK" unit, there is a hex nut/plug on the first and second stage filters that needs to be backed out to let the fuel flow freely for bleeding the 2nd and 3rd stage filters, a correct operators manual is a Must for proper preventive maintenance
cnt
Between the first and second fuel filter
there is a hex head nut take it out pull
the spring and plunger out put plug back
in loosen bleed screw on top of third
filter a lil air from the air compressor
til ya get fuel out the bleed and put the
plunger and spring back. Just did it a
week ago on my 830ck
(quoted from post at 17:24:38 02/09/15) Between the first and second fuel filter
Alright thanks I will try that.
