Case 730 gaskets
MarkE
I see some sparks coming from the exhaust manifold. Does this mean that I need new exhaust gaskets and ferrules? Should I replace the intake gaskets and ferrules at the same time? If so, where to find them if my Case dealer doesn't have them? Part #'s for the intake gaskets(A 7363), intake ferrules(A21634), exhaust gaskets(A 27909), and exhaust ferrules(A21635). My usual experience at the dealer is that these original part #'s are obsolete and they have difficulty obtaining the replacement #.
Thanks, Mark
I bought a set about a year and a half ago from our local Case dealer. You probably won"t have to replace the intake ferrules as they don"t get much abuse. I think the 4 exh ferrules cost me about $65/70. Add about $50+ for the gaskets but you can find the gaskets aftermarket. Since you"ll have it apart you may want to have the manifold ports cleaned up by a machine shop so the gaskets will seal right, especially if you"ve had bad gaskets for a while. Have them take as little as possible off. I had that done for about $50ish. If you do that you may have to file the ferrules down a bit to get things to fit right. as the manifold ports will be a bit shallower and the manifold won"t fit tight to the heads then. Good luck.
Thanks so much for the advice. I have a friend who has all the equipment to skim off any imperfections on the manifolds.
Mark
That is true for the 400-700-800-900's but not the 30 series. I've made them for my 800. The 730 uses a stepped ferrule that has a different diameter on each end. To make those you'd have to have 2 different sized pipes and weld/braze them together.
