Case 800b specs
Yes I do not see why not unless the haybine takes over 1500 psi to lift it HP wise you should be fine, I ran a 14' hydro-swing with a 730 gas, rated the same hp as the 800B for years no problem in 2 ton per acre hay
cnt
I ran a NH small sq with a thrower, with my Racine 400, no problem. It mowed with my Case IH 1190
mower/conditioner with no sweat. I even ran my NH 851 chain baler in a pinch one time when the 1070 was
down. It did fine, I could't roll a full 6' bale, I'd stop around 5' when the tractor would start
pulling down. Those long stroke diesels are amazing.
Is your unit a sickle mower or a disc mower CNT? I thought a 9' disc mower would be a bit much, though I haven't tried with mine.
14' Hesston 1014 and a 1014+2 with conditioners running 4-5 mph, I thought he said a Haybine which to me is a sickle type machine, sorry if I misunderstood,
I thought that's what you were thinking!
The one other thing I would mention with an 800, is you mount those things from the rear, so be absolutely sure you DISENGAUGE THE PTO before getting off the tractor!
A 9' disc mower might push a 800B on hilly ground in heavy first cut hay, but with the COM tranny no problem. Just flip the direct drive lever up and down, and enjoy the ride, in likely 5th gear.
Loren
