I rebuilt an 830 case o matic a couple of years ago and it has been running fine. Recently right after startup, warm or cold, it seems like the torque converter has drained down and needs a minute to refill. Gauge pressure is good, just wont engage right away and takes a minute to slowly engage. Then it works fine for as long as I a using it.
I checked pressures.
Clutch pressure 200, but it drops to 165 with the rpm.
Pump pressure @200
Converter pressure 25 psi.
I swapped the control valve with a spare and clutch pressure is only 165 dropping with rpm. I didn’t check shims.
Converter 20
Am I looking at a torque converter leak? Ill check the housing bolts when I swap the control valves again. Could the hig clutch pressure have blown a converter seal?
Pump pressure @200
Converter 20
