Case 830 Comfort King
Muleman2
Need some help on the wiring to and from the key switch. also I am going to a one wire alternator and a amp gauge . Need a little info. on the wiring setup also. Thanks, Muleman2
Does this offer you any help, this is the best I can come up with.
More information would greatly help.
What are you changing? Going from a generator to an alternator? A complete rewire? Adding an amp gauge or replacing one?
If you are making changes, you won't find a ready drawn wiring diagram, you will be redesigning the portion you are modifying, and we can walk you through that.
A one wire alternator is a very simple modification, it involves removing unused wiring from whatever is there now.
If you are considering adding an amp gauge, I would recommend a volt meter instead. Much simpler, and less to go wrong.
Let us know...
