case 830 power steering cylinder
Chris830930
hi i have a case 830 with power asset steeing im having trouble getting the cylinder apart i cant get the threaded end loose ive heated any suggestions would be great maybe im going about it wrong in talking about the valve end thanks
The end is staked, i.e. there are a couple of tabs on the cylinder tube that are bent down at a 90 degree angle to prevent the end from turning. Bend them up parallel to the tube, and it should unscrew.
I had a similar problem on an SC 3pt lift cylinder. Took the retainers out, pulled the snap ring out, used the internal piston as hammer against itself, couldn't get it out, used a come-along with it chained up on my trailer for days and no movement. I sent Mel a message and he told me to take out the side fitting as it went through the cylinder and I was pulling against the fitting. Took the fitting out and the cylinder plug end almost fell out with the piston. Boy did I feel dumb.
So my question to you is do you have all of the hose fittings unscrewed that can come out and the cylinder stripped down as bare as possible? Could be something like a fitting that is holding it together if its not like Bradley's cylinder.
