Case 830 Water in oil
so here is the story i replaced the head gasket last fall well my friend did and he didn’t retorque it after it ran for a bit i just took it apart again because there is water in the oil again. i did retorque it and some of the nuts did tighten more and some didnt. I haven’t added oil back in I didn’t want to wast it if you didn’t think that was the problem. do you think that is why i have water in the oil again or do i have a cracked sleeve or head or o ring. Hoss help me out here please...thanks if any one else has an idea i'm open for any suggestions
thanks
Aaron
I would pull the oil pan and set a clean container under the engine and see if there's any leakage from the sleeves. You may need a good light. Hal
Hello Aaron,
you can test the engine before putting oil in it. if you fill the cooling system and pressure test it with the oil drain plug out you will see if it leaks. I would pump it up to 10 psi and let it sit over night. if you leave some coolant out so you have a air pocket in the top of the radiator you will hold pressure longer. Napa has pressure tester for around $50.
good Luck Ed
Abcrepairparts
I pulled the heads off today and there was some coolant on the head gasket and afew spots from where it looked like it had been wet. But it could be from me taking the heads off. i am going to put it back together im borrowing a pressure tester tomorrow morning to see if i see a leak in the sleeves. i looked for cracks in the sleeve from the top i'm really trying to not have to pull the pistons out so i hope the pressure tester tells me its just the heads needed to be tightened thanks for your ideas every one i'm ganna keep at it can anyone tell me how slow the Case o Matic drive goes the reason i bought this one is i need to go slow as i can without being stopped and be able to speed up from there
Unless you can find a definate place where it was leaking I would not put it back together. Your description was that there were some bolts that were up to torque and some that were not but if they were close that should keep antifreeze out of the cylinder. I would have the head magnafluxed and carefully look at that sleeve. You should be able to see where the compression was leaking as evidenced by a dark black area across the steel compression seal on the head gasket. Do you have someone who works in the heavy truck field who is familiar with wet sleeve engines you could hire or otherwise convince to look at it? I don't want to see you waste the money for a new gasket and see you do it all over later. mEl
(quoted from post at 23:21:44 02/18/11) you obviously have NO idea what you are talking about
Since you didn't identify who it is that don't know what they are talking about it kinda leaves us in the dark with a random comment like that. Everyone that comments does so within the realm of their knowledge. I to find some responses humorous knowing the tractor being worked on but everyone is trying to help within the scope of their knowledge. I could take exception to your comment since it immediately followed mine but I won't since my lifes work has been centered around Case tractors and I am comfortable with the knowledge that I have gained since 1962 when I started full time at the job where I am still employed as head mechanic. mEl
