87thhunter
Tractor was blowing flames out of the exhaust, and timing was way off. Stopped blowing flames but there is still a miss/pop.
Now if i leave it in the barn, you cant see your hands in front of your face, horrible eye burning grayish smoke.
Any idea's what this could be im leading twords a bad injector. Far as the miss/pop starting fluid takes that right away, and/or if it is under a heavy load. But you cannot start the tractor and expect to leave it parked inside (doors open) as it will fill the room within 30-45 seconds.
Engine has been overhauled.
Any input/help would be greatly appreciated.
Are the pre-cups in good condition? Also is the camshaft and /or injection pump timed correctly?
If they look like this that could be part of the problem,
This one came from a 900, was missing a bit and eventually ate a hole through the plug, I had to change it for a friend luckily it didnt go into the head. There were no flames just a slight miss, when i went to look at it, it sounded like a manifold leak then i saw the exhaust coming out the plug for the powercell. Put in a new injector and New powercell came from Don Livingston
Ben
I will get the injectors rebuilt, i work at a used parts/equipment yard. And am going to send out 4 injectors that are on the shelf. Far as the power cell's i had the heads checked around 5-10 hours ago and they said they where in good shape. But i never did see them. Thank you for the replies and hope the injectors fix the problem!!
The timing i am going to go and recheck everything again just to make sure its all set correctly. and i know i have to make sure the pointer is set correctly, considering its 40+ years old, who knows how many belts hit that thing
I have seen two other things cause problems like you have but this may not be it at all either, I have seen the harmonic pulley slip on the rubber and that throws timing out the window, to check this the pulley has two marks in it on each piece they must be lined up, the other is the pump can have internal damage that will make it do this good luck please post back to let us know what you find, it sure is nice to know you got the problem solved
cnt
