Have used an 8465 for many years. Currently struggling with bale shape sensors. They work erratically. Drive "left" has 2 arrows then 4 then 3 and just jumps all over the place. Drive "right " has 4 arrows all the time. Never changes. The monitor set up sometimes says adjust cw sometimes ccw. But adjusting them seems to make no difference.
So which physical side of the baler triggers the Drive "left" arrows?
I tested resistance (ohms) on the physical left sensor as seated in the operator seat. The first good distance of travel reads 346 ohms and then it finally counts down to 106 or so in the next very small amount of travel. Seems fishy. I got disgusted and just baler while ignoring arrows as I have the last several times I baled. Up until this year they had worked well. This year when initially having problems I found 1 sensor arm missing. Replaced it and thought it would be fixed. Nope. I adjust per manual and monitor instruction as we have in the past for this baler and the prior, also an 8465 that caught fire DOH!. But to no avail. Google seems of little help as well. The 8465 guru in our area died. Anyway, any ideas? Can one still find these sensors to replace them? I have had no luck this far and the parts baler I have found are missing the sensors already leading me to believe they are no longer available. Thanks in advance.
