Case 850B transmission hoses
Pat80flh
Morning folks, I have this well worn 850B that started leaking trans oil. I pulled the rear skid plates off and a rubber hose in the middle of the right cooler line is leaking. There is another hose from converter to trans that has a cut in the rubber sheath. that I'd like to replace while I'm there. NLA on Case website, are these available aftermarket? Or do I need to go somewhere that makes hydraulic hoses and have them duplicated ?
Is this the diagram? CNHI Case 850B hyd. Cooler diagram There is only one right hose. (Edit: At first my brain thought you wrote 450B so that is the diagram I attached, changed now. I see the 850 has two coolers so maybe this is why you are saying “right”)
Did you try a web search with the number they show?
