I'll have a look, thanks! I'm pretty sure mine mount on the lower area of the transmission case for some reason though...There should be a place right under the platform to hook them and on the pedals one for each. That's the way most tractors do them.
Here's a link to the parts catalog brake pages.My Case 930 (1966 Diesel CK Western Special) is missing the brake return springs and I can't figure out where to install them on the brake pedal linkage. I have new springs, just wondering if anyone has a picture of where they're supposed to go.
Thanks!
Great! Thanks a lot!Here's a link to the parts catalog brake pages.
https://www.mycnhstore.com/us/en/ca...BE-E111-9FCE-005056875BD6?categorySearch=true
I hope there's enough detail to be of some help!
Unfortunately the diagram doesn't show where the spring goesHere's a link to the parts catalog brake pages.
Ohh alright, I've found the pin, not sure where the attachment on the brake itself is. I'll look a bit later! Thanks.They go down by the rt side brake and are hooked to the pin and on a piece of plate over the brake housing.
There is a formed angle that bolts to the outside of the brake housing and goes up and over the housing, it has 2 holes for the springs.Ohh alright, I've found the pin, not sure where the attachment on the brake itself is. I'll look a bit later! Thanks.
Great! That sounds familiar. I'll check my brake housing, thanks!There is a formed angle that bolts to the outside of the brake housing and goes up and over the housing, it has 2 holes for the springs.
Had a look at the brakes again. There's about a 6in. rod bolted underneath the brake housing with two grooves for the springs. Couldn't find the other attachment point, though I assume it's somewhere on the rear brake assembly joint.There is a formed angle that bolts to the outside of the brake housing and goes up and over the housing, it has 2 holes for the springs.
As you can see in this pic from the link above, from the peddles is a rod (no. 23) going back to the arms (26 and 27), one for each side. The spring is the keeper for the pin (48) that hold the rod to the rear arm and the angled plate (45).Had a look at the brakes again. There's about a 6in. rod bolted underneath the brake housing with two grooves for the springs. Couldn't find the other attachment point, though I assume it's somewhere on the rear brake assembly joint.
Ohh I see that now, thanks alot for describing the diagram, I'm pretty terrible at reading some of those. I'll have a look at the various components tomorrow and get back to you. Thanks again!As you can see in this pic from the link above, from the peddles is a rod (no. 23) going back to the arms (26 and 27), one for each side. The spring is the keeper for the pin (48) that hold the rod to the rear arm and the angled plate (45).
Had a look, I believe that parts manual is for the General Purpose as my setup is quite different. I'm pretty certain the spring needs to attach to one of the lower pins on the rear brake connection bracket, but I'm not sure how.As you can see in this pic from the link above, from the peddles is a rod (no. 23) going back to the arms (26 and 27), one for each side. The spring is the keeper for the pin (48) that hold the rod to the rear arm and the angled plate (45).
dang, I missed that it's a western. I can't help much thereHad a look, I believe that parts manual is for the General Purpose as my setup is quite different. I'm pretty certain the spring needs to attach to one of the lower pins on the rear brake connection bracket, but I'm not sure how.
No worries! Thanks for looking!dang, I missed that it's a western. I can't help much there
