CASE 930 Clutch Adjustment
Moridin
Is anyone able to help with the clutch adjustment for a case 930? I have reviewed the manual (not the IT service manual) and I have read what it says. However I don't have the tool that is necessary and I was hoping for a picture so that I could fabricate something that would work. I am trying to help my Dad do this. Any sort of information or help that you could provide would be greatly appreciated.
Take a piece of 5/16 rod and heat and flatten one end. Grind a notch in the flattened end and add a slight bend about two inches from the end. Should be able to pry the button out while you turn the collar.
I assume you have a six-speed 930? hand or foot clutch or do you have a 8 speed model? here are the steps for the six-speed models, I added both foot and hand clutch versions, I can add the specs also if you need them, this are for the rear tank 930 six speed, I can get the steps for the early 930 you got on from the rear also if thats what you have ,, there are three different versions of the 930's where this adjustment is needed,
cnt
