Case 930 Oil capacities
Ryon
I just purchased my first Case tractor, a 1961 930 Wheatland with a hand clutch and want to change all the fluids and can't find that information anywhere. How much oil is in the transmission, does the hydraulics use the same oil or does it take separate oil? How much engine oil does it take. I drained the transmission and got 23 gallons out - is that right? Just need some information. Thanks!
(reply to post at 15:26:16 04/18/10)
Hydraulics should be 16 gals of 80/90w and the hydraulics takes 14 qts of type A oil or good grade hydraulic oil like hy-tran or Mastertran. Engine also takes 14 qts including filter. Be sure to drain the clutch, install plug then run engine, clutch housing will refill from engine oil.
caseman-d
This is taken out of a 1966 930 CK book ,but the cap. are the same for the 1960-66 chain drive models. Crankcase 14 qts with filter, trans 15 Gal. the 1966 calls for TCH The 1960--?calls for 80-90W I put 80-90W in my 1966 CK at 2000 hrs. and have had no trouble, now have 8400hrs. . Hyda. calls for 14 qts. of TCH. I now use Case HY-TRAN.
From the 1966, 930 CK instruction manual.
I bet a bunch of it was water. Did you check to see if there is a bunch of condensation water laying under the oil?
Jim
