Case 970 Power Shift Missing Parts
Hello all,
So after some advice if received from here, I went ahead and pulled out my power shift assembly. Tore it down, soaked the body, then brushed all the ports. cleaned all the spools and parts. But as went to put together I appears I am missing a couple parts. I can get two of the parts for the dealer. One is not available. What is everones opinion on how important are they? I have listed them and attached a diagram.
Spacer A37555 Available
Spacer A37554 available
Stop A62640 Not Available
The early valves did not have that stop, trans SN 2366001 transmission SN and up used the stop, be sure to give your dealer the trans SN when ordering any Power Shift parts. The washers are selective to set the lube pressure and any grade washer added there will do. The lube pressure may have been on spec without any washers, if so you are not missing them but may have to add a washer or two to get it to spec as the spring may have lost a bit of tension over the years.
This post was edited by mEl on 06/28/2021 at 10:01 am.
