Cih7220
Hi there.. new to the forum and have a question regarding my 970.. i noticed the tractor slipping when pulling so slpit it and found the tourqe limmiter was shot.. replaced it and when I put it together and tried it I couldn t get the 4 speed in gear.. push the clutch or foot-inch in and tractor surges slightly then labors like something is not releasing.. pressures are all good and the book says something about a rps valve orifice that coulb be plugged.. problem is i have no idea where this orifice is located.. any help is greatly appreciated.. thanks
Update on my troubles for anyone who can help.. rebuild of the
power shift control valve fixed my problem with the laboring and
shifting the four speed.. tractor works great through all the gears and
powershift.. problem now is i have no reverse.. put it in and it tries to
move but just barely.. all pressures on the control valve are 145-150
range which is low according to the book.. question is.. what should
be my next step? Thanks and i will keep trying i just hate the feeling
of chasing my tail..
Case 970 update.. added a shim to the flow devider and got pressure up to 180 on all ports but the c4.. push the clutch in or put in reverse and c4 pressure is only 120.. lube pressure port is at 50-55.. any info would be appreciated.. thanks
Quick catch up for anyone who may be interested.. finally got the 970 working great.. tore the tractor completely down and discovered that the c4 piston was cracked and leaking.. also I found that the spring washers in the c2-c3 clutch packs were broke.. got her back together with the new parts and i am good to go..
Quick note.. dont go to the case dealer and spend 70 couple bucks on those spring washers.. a place near Pittsburgh makes them for 18 bucks.. thanks a bunch to the guy who posted that in 2013..
