Case bulldozer
Scott Leiser
Trying to verify and track down parts for a dozer I just bought. Believe it's a 1000-c. Spent many hours online and many phone calls and had no luck. All the local consteuction equipment dealers stopped dealing with older equipment. Really need help teying to fix her up and make her reliable again. Euns amd operates. Just need wear parts and other stuff. Thank you in advance.
A couple dealers you could try are Coleman Equipment in Kansas and Beauregard Equipment in Vermont. John Saeli, who often posts on the Case Forum, might have some ideas as well.
Adding your general location to your profile might help folks remember someplace they have used close to you. What are you looking for, wear parts and other stuff is a pretty broad scope. Some wear parts and other stuff can be located aftermarket.
Wear parts such as idler wheels/boggie
wheels for track. Pins for 2 way blade.
Drive sprockets, Brake master cylinder,
thats about all it needs so far. Have a
coolant leak but not sure that it's the
radiator yet. Located it wooster
ohio,sorry should of posted location
Have a machine shop make the pins you need. Take the master cylinder to a NAPA or good parts store, they maybe able to match it up.
Idlers, sprockets, rollers can be gotten from after market suppliers of tracks for many machines. Look on eBay, or do a web search for your area, for crawler tracks to get some places to contact. If you are going to replace sprockets you should replace the chains as old chains and new sprockets (or new chains and old sprockets) don't wear well together. to add to what marloweg posted; you want to be setting down as you are looking at thousands of dollars if you aren't aware of the cost of undercarriage parts, if you can find them.
I'm not here to discuss personal opinions on prices. Thanks though. Id like to focus on tracking down someone who is knowledgable about these machines and how to track down the parts aftermarket. I have a local machine shop to take care of some pins an bushing type stuff but the actual case parts such as master cylinders, sprockets etc. Cant be found locally so I'm looking for some names of places to look etc. Did alot of searching online, and online stores such ad ebay and such with not much luck. Looking for helpful information so if you're not educated on these machines then give your opinion somewhere else. I'm in the machine for almost nothing, just have to fix a few odds an ends things for a grand or 2 an I'll have a nice size reliable dozer for 3k. You don't get any type of dozer this size for 3k
Ok I admit I don't have specific knowledge on a Case 1000C and can't tell you to call ABC and they will have just what you want, so you can ignore this if you want.
Many people here have knowledge to help, but it may not be specifically on a Case 1000C. Many times suggestions have been made only to have the requester say it costs too much, so cost is often mentioned, just a fact that comes with asking questions on open forums. I won't say your machine is not worth it; that is something we each decide for ourselves, I have repaired things others said to junk. I just know that undercarriage work is more expensive than many people estimate, so I mentioned it, it was not intended as a put down.
Do you have a parts book? If not find and get one for your machine. There are some on eBay, for one place. Being able to provide and look for parts with the part number is a plus and can help your results. Clean your machine tag and confirm the numbers so you get the right manual and parts, there may well be serial number breaks where parts change. There is an on line parts book at the Case Construction Equipment but it is for serial number 7103001 and up.
NAPA or a good parts store can cross/find a master cylinder in most cases, I have had that done before. You did you pull it off and see if there was a name or casting number on it and take it in for them to see, or did you just ask for a master cylinder for a Case 1000C?
For undercarriage I searched for Ohio crawler undercarriage dealers on the net and can see a couple in Ohio and several that will service Ohio. You should be able to find them with a similar search and decide on the ones you want to try contacting. I can't tell you which ones to call, you might have to try several to find what you need. Also most John Deere, Case, Cat, and other crawler dealers have access to a line or two of aftermarket undercarriage parts for machines other than the brand they sell. You are going to have to call and talk with them, they generally don't have a full selection catalog you can pick and chose from. Your 1000C may be able to use undercarriage parts from a different machine, the dealer should be able to help with that. They may have to check further "up the line" to see what will interchange to your crawler, because of its age and popularity. You should be able/ready to provide them with the number of links, approximate pitch and width of your chains, info on the rolls, pads, sprocket bolt up, etc. to help be sure you are getting comparable parts. and there are often different grades/types. They may ask for other info as well.
If this is all info you already know/have, sorry for taking your time, good luck with your search.
Jim.me. appreciate that. And no I knew
parts would be difficult so the master
cylinders an such IV pulled off and got
the name an casting number off to find a
match or cross reference to a similar
one. Idler wheels dont have a part number
casted in them and the sprockets IV
called many construction dealers with the
casting number and didnt have any luck.
Alot of construction dealers in Ohio but
all that IV talked to quit carrying older
stuff. The other parts that were able to
be made by a machine shop are going to go
there. Other than that its just fixing
leaks with hoses an fittings, stuff you
can find at your local hydraulic shop or
parts store. Just need the master
cylinder, sprockets, and a idler wheel or
2. An older post was made by a guy named
George md and id love to track him down
but it wouldnt let me reply to him. Far
as a parts book I havent ordered it till
I know 100% what the machine is. Books
are about 70 bucks or so, so i didn't
want to order one for the wrong machine.
Thanks for the information, shes gonna be
an interesting project thats for sure.
Scott,
Plain 1000 to ser# 7101200 , 1000C to ser # 7103000.
There were some fairly major changes in the first 1000 group,
C had larger suspension pins,plating on the track frame by
the front wheel,closed trunion pivots and greasable where the
early ones were open. I have some of all models including the
factory rebuilt ones called a 1000BR
I have both parts and service books on CD.
Send me an email with a phone # and I'll call you .
george
George md. I seen an old comment of yours and it wouldn't let me comment. I was really hoping I would get ahold of you. Would love to talk about this dozer I just got. Trying to get it back in good enough shape to be used on our farm. It wouldnt let me email you but please get ahold of me at 330-749-5435. You would be a life saver.
