CASE CC ENGINE SWAP WITH DC PROBLEM
Mild Bill
I PUT A DC ENGINE IN MY GRANDADS 34 CC CASE 40/50YRS AGO WITH NO PROBLEM. NEED TO DO IT AGAIN. ENGINE I HAVE HAS A PLATE BLOCKING THE SPLINES OF THE CC TRANS. I F I CAN GET IT OFF WILL I THEN BE ABLE TO SLIDE THE SPLINED SHAFT OF THE CC INTO THE DC OR NOT??
Can you send Pics, I can't visualize what plate you are talking about? If you are talking about changing the input shaft to the transmission, the input shaft and its mating gear in the transmission are a matched set and should be kept together. Depending on the year, the transmissions on DCs even are different, my 39 has 2nd and R interchanged from later models. Most Ag CCs were hand crank and did not have the bulge on the transmission case to match the starter opening on a DC block. Industrial C series had bell housings generally to accept a starter. All of the transmission shafts were 1 3/4 6 spline so that is not an issue, the engine should fit directly but the clutches differ depending on the year, pre 41 I believe was the old style and after used a totally different clutch assembly, there should be no need to change transmission shafts. I am running a later clutch in my 39 with no change to the transmission input shaft.
If the bell housings are the same you do not need to change the input shaft to the transmission, I still do not have an idea which plate you are referring to as nothing like that has to be taken apart to change engines if you were converting to the later from the early style clutch your external clutch linkage would need changed but nothing internal to the bell housing. either clutch takes the same input shaft to the transmission. if the plate you are talking about is inside the bell housing it does not need to be changed to make an engine swap.
