case cc high compression pistons sleeves
I put nos high compression pistons for C-D series tractor in a cc case I'm using a 5505 head not nuff room pistons hit the head is this set only for 5576 head 250 cc I'm using 5505 head 200 cc. From top of old piston to top of ring is 3/16 inch new piston from top to first ring is 5/8 can anyone give any pointers
Not sure which high compression pistons you are using?? The common high compression I see can go with the 5505 head but not the 6128 lp head.
The pistons I've used are flat with a raised section that goes up into the valve chamber and are 4 1/16 inches diameter.
Will be hard to hand crank that cc to start
AS far as I know the only head that would accept pistons coming out of the top of the bore would be the old very low compression head off of a early DC with the spark plugs coming straight out the sides, it is a big open chamber head with a straight wall opening clear to the roof of the chamber and would easily clear those pistons.
IF I HAD THAT ISSUE and all parts are brand new I would have some one measure the thickness of the piston crown for thickness and if the piston crown is thick enough I would shorten the pistons to approximately .040 below the top of the sleeve, I have a fixture made to pull the piston back into the lathe chuck, a threaded rod that goes clear back through the lathe chuck and shaft and secure it through the wrist pin hole with an eyelet off of a dual wheel clamp setup, at the lathe back end I use flat washers and a nut to pull the piston back and use the chuck to center it on the skirt. This is a recommendation only if the piston crown will be thick enough. f you can come up with the piston crown thickness WE can help figure the piston top thickness.
Are your pistons 3 7/8? I have several sets of pistons that will come up flush with the top of the sleeve. I would be glad to trade pistons. Do not cut yours down! They are to hard to find. E-mail is open.
D that would be a reasonable solution if indeed they are 3 7/8, he did not state and I thought probably 4", they would be a nice addition to an old low compression setup , hope you can help him out.
Yes 3-7/8 pistons already installed in block my 5505 head has new guides seats 30 off deck.
5576 head I have has to go to shop if I use that one gonna stone boat it for just fun nothing serious.
Those pistons are to high for the 5576 also, If they are 5/8 higher in my opinion the only head they will work with is the very early gas head.
I have a CC with 4 1/16 bore sleeves in it. My pistons are flat top and lack about 3/16 inch of coming to the top of the bore. I`d like to have some that come all the way to the top of the sleeve. I`m using a 5505 head. Any ideas?
Looking at your piston standout if the gasket is .080 thick there may be enough clearance to run the 5576 head, I would do some measuring, the shallow step in the 5576 head may be deep enough to allow that high piston to clear. when In doubt we use solder to check the thickness, put it in the areas where you are in doubt, bolt the head down and turn it over, disassemble and check the thickness of the solder to see how much it crushed, that will be your clearance
0.080" gasket is between 5/64" & 3/32" so you're almost ballpark with the piston standout pending gasket crush. Leads are the way to go as mEl wrote.
Joe
