Case DC and Case SC
Clifton1979
I have just obtained two older case tractors. One is a 1951 Case DC and the other is a 1951 model Case SC. The SC has an adjustable wide front, a cracked block and is locked up but hopefully the transmission is fine. The poor little SC has been butchered up pretty bad, it used to be a gas tractor and has been converted to LP, the previous owner has cut up the sheet metal to fit the LP tank it and looks pretty bad. The DC is a narrow front, turns over good and has good compression, both of the these tractors have been settin since 1988. The DC is missing a front wheel, hub and rim, who would have some of these parts. I have contacted worthington ag parts and they have one but would love to find one under 150.00 if it is possible. Any help would be greatly appreciated.
Those arent what I have on mine. I have the hubs that are a large cast center with clamps that hold the rim on, kinda like the same set up on the rear as far as the clamps. It has no lug nuts that hold a conventional rim with a center piece to the hub.
Get the DC, you will ove it. Try nebraska cowman for a front wheel, he parts out a DC from time to time, or try Miller Repair in Maxwell, NE
(quoted from post at 17:11:17 06/30/11) I have just obtained two older case tractors. One is a 1951 Case DC and the other is a 1951 model Case SC. The SC has an adjustable wide front, a cracked block and is locked up but hopefully the transmission is fine. The poor little SC has been butchered up pretty bad, it used to be a gas tractor and has been converted to LP, the previous owner has cut up the sheet metal to fit the LP tank it and looks pretty bad. The DC is a narrow front, turns over good and has good compression, both of the these tractors have been settin since 1988. The DC is missing a front wheel, hub and rim, who would have some of these parts. I have contacted worthington ag parts and they have one but would love to find one under 150.00 if it is possible. Any help would be greatly appreciated.
Try Booseman Machine in Lubock , Tx. They ought to have what you need.
