Dear lads
I just replaced the engine rings and all the gaskets on my Case Dc 4 and now the tractor does not want to run I hade it running for about a minute and it quits and will not run for a wile then when I try to cranked in cranks easily but one spot is real hard also oil is coming out the new head gasket when I cranked I also have 40 pounds of oil pressure and spark
Matt,
It sounds like your rings might be too tight and something could be wrong with the way you installed your oil rings. Were you sure to check the ring gap before you put everything back together? If its that tight, you better take things back apart before you do some real dammage to the inside of your cylinder walls.
