case IH 585 steering problem
addibeck
I have a Case IH 585 that only steers to the right. It first broke the fitting on the end of the steering cylinder shaft while turning left. After replacing the fitting it would only turn to the left a little and broke the fitting again when it bottomed out. Now after replacing the fitting again it only turns right. When you turn the steering wheel left the steering cylinder extends and will bottom out breaking the fitting again if your turn too far, but the wheels don't turn left. It turns full right just fine, but won't turn back.
Anyone know what this means?
Thanks for your help.
Get a helper and lay under the tractor while they steer it GENTLY. Something is moving that should not be and hitting the fitting,or the cylinder is moving.Wear eye protection.Mark
