Just bought a 1949 Case LA. Changed oil. Online specs say 15qts. Took 9qts. Where there different size pans for these engines?
Magneto point sleeve (manual advance/retard for start/run) is rusted solid in run position. Does this matter when using electric starter. What is the test procedure for the generator, has 2 coil voltage regulator with two wires coming up out of the center of the generator and attaching one each to the bottom side of each regulator coil?
Z/
Z/
