Case mod 31 backhoe swing cylinder
dadeni
1963 Case mod 31 backhoe swing cylinder
I can not find a seal/ pac kit for it. All the ones I can find go to model 32 backhoes. They have a 4" cylinder bore mine has a 3" bore.
Any help would be appreciated.
Bring the old seals to your local hydraulic shop, they should be able to match them up for you.
AJ
(quoted from post at 17:41:15 10/24/21) Bring the old seals to your local hydraulic shop, they should be able to match them up for you.
AJ
Thanks for the quick answer. I live in a very rural area. The nearest hydraulic shop is about a hundred miles away. I was hoping there was a place I could order them online but you are probably right .
Thanks Dave
(quoted from post at 13:08:31 10/25/21)
AJ
Thanks Dave
Check out Baum Hydraulics, maybe even call and talk to someone if what you see in the catalogs doesn't appear to meet your need.
