Case model C Starter???
Hello Has anyone herd or seen an electric starter that could be put onto a 1937 Case Model C? I have a bad back and it is very tuff for me to crank start this tractor. I like it too much to get rid of so I would like to convert it to electric start. Thanks
it can be done through the pto seems like a picture of one was in old abes news could be done with belt on belt pulley both are not real good methods but possible how about working out a trade for a 39 dc same rear end but with road gear
There was a post here in late March showing a photo of a starter attached to the front of a C. It looked like a very practical arrangement that would work on any tractor with a crank start.
Search the archive for it.
Saw one that had a ford flywheel bolted to the outer half of the flat belt pulley. Then made a mount base for the starter. Looked odd but worked.
I have a 1935 C with such a starter and it works great. It uses a ring gear welded to a shaft which attached to the old crank slots. I would be glad to send you a couple of pictures. [email protected]
