Case Nutty and others
fastfarmall
Ny friend Loren called, another combine followed him home, this time it's a G-4 M-Moline combine. hes got the motor to turn, but when number 2 @ 3 come to the top, it locks up solid,rock solid,what do you think is going on ? It's a Z tractor engine, it been inside all it life!
if its not a stuck valve which would be my first guess it could have had a rodent pack a cylinder with seed,, easy to check valves by making sure they all move freely by lightly tapping on them, to check for debris in teh cylinder remove all the plugs and use a air gun to blow in the hole, do not seat the air gun in the hole just blow air in it, if there is stuff inside it will start blowing out
I wouldn't think stuck valves would lock it solid.
The valves won't hit the piston.
A stuck closed valve would bend a pushrod instead of being a solid lock up.
It could be a broken valve, but usually a valve breaks running and punches through the piston, and will still turn.
I'm going with the rodent nest, or something unrelated to a cylinder.
He ruled out the rodent nest or what ever, it hitting some thing solid,he can get gasket set, yet so he will have to take it apart, but thanks guys !!
