Case-Roosa-Master DB
Scissorman
I have a 1968 case , 580ck. The fuel injector pump, a roosa-master DB not working. First, anyone out there fix these for a reasonable price, like $250 or so. Where do I get complete parts diagram?. Fuel enters pump, when motor turning over, no fuel being pumped out. It ran in March, I turned it off, now won't start.
If there's been any traces of water in the fuel it will probably have the metering valve and plungers stuck, along with other parts too. Have a Case 570 pump in now for the same trouble. It will get a complete tear down, cleaned, repaired, and tested. Most with time and materials run between three to four hundred, including return shipping. That's IF the hydraulic head is not seized, and drive shaft broken..
