Case SC hydraulics
IHguy86
I just recently purchased a case SC, I believe a 1950. The two lift arms on the back of the tractor lift very slow and do not lift at all with a little bit of weight on it.
Hoping to see if anybody can help me fix this issue?
Have you checked your hydraulic fluid level? There is a check plug below the seat near the PTO. Hy-Tran fluid will work if it?s low. There is also a
hydraulic filter that may need replacing below the PTO on the right side of the housing.
Jim
Jim
(quoted from post at 14:40:49 08/27/19) Have you checked your hydraulic fluid level? There is a check plug below the seat near the PTO. Hy-Tran fluid will work if it?s low. There is also a
Jim
Is it one of these two holes above the arrow just below the tool box?
It?s been awhile since I had my SC. The large hole is the transmission fill, the small hole is the hydraulic fill. The level plug for the hydraulic is about 1/4?
square head located just above the right side of your arrow..
You need a service and operators manual for your tractor, easy to get. That will answer most of your questions.
Jim
(quoted from post at 15:23:02 08/27/19) It?s been awhile since I had my SC. The large hole is the transmission fill, the small hole is the hydraulic fill. The level plug for the hydraulic is about 1/4?
Jim
Great this is a big help, appreciate it!
Ryan
