Case SC wide to narrow front
ILB
Case board members, Is it possible to put a narrow front on a wide front Case SC tractor? If so, easy, hard or can't be done. Are narrow fronts available?
It sure can be done, I've gone back and forth over the years with the same deal, depending on what the tractor is doing. The most difficult part is changing the front casting. That cast iron is heavy, particularly with that weight bolted inside it...... Drop me a line if you have questions. Email is open....... Larry
