Case VAC pulley
I received a pullery in excellent condition from a fellow on this forum. While waiting for it to be delivered I decided to check out the rest of the pulley "system". According to the operator manual engaging the pulley involves removing a tapered set screw and merely pushing the pulley shaft toward the tractor, then re-installing the set screw.. Mine does not "merely" slide. I have Oxy,Acetylene to apply heat and can dismantle the entire assembly, however I notice that it has cone bearings.
My question is two fold. First: what is the initial approach? Apply heat or go for disassembly and then heat? And second: is "snug" a correct pre-load for the cone bearings?
