Case Vac Vt-148 Head
430 Case
I bought a 1955 Case VAC -14 with a cracked block. Purchased a VT-328 Block and a VT-148 head. Overhauling the engine - installing the head to the block, discovered the four outer holes has a raised flange, and the original head had a flat flange. Assuming maybe the head I bought was the older head made by Continental? Used the original block studs and they are a little short on the 4 raised flange areas. Is it ok to back those 4 studs out of the block a few threads? Or are longer studs required?
Longer studs, why take a chance of stripping the fewer threads in the block especially on a stretched stud that is constantly stressed as the engine fires. In ship building short threads is called "short studding" sometimes requiring hundreds of bolt/stud replacements.
You are correct Sir.
Longer studs.
