Case VAC with Case 100 Loader
NickatKY
Case VAC-14 and Case 100 loader. This tractor was bought new by a township in Wisconsin for snow removal.The snow bucket is a rare option for a VAC loader. This tractor was originally built with an adjustable wide front and was shipped without a pto from the factory. I plan to put the correct wide front back on it. I believe when the township sold the tractor it was used on a farm and the tricycle front was put on to cultivate and was handier for cleaning manure out of the barn.
Here's a pic of my Case 101 loader for SC/DC tractors.
I have not used it yet. It needs a little tlc to be able to use as it had set for several years. From what I could tell it did operate the loader fairly well. The 2 boom cylinders are probably dont need any more volume than the rockshaft. When I get it going again I will give you an update.
It is rated to carry 1000lbs and breakaway at 1550
Nick
Hi Nick, just got mine unloaded today from trailer, mine is in pieces which is nice, as I can get cylinders rebuilt and work on the new mounts. Good friend of mine can make me a set of mounting brackets with square tubing to fit my 48', which will give me 2 different sets, then it could be used on nay year VAC.
Mike.
Nick that is a nice unit. I think I have the pictures of the loader you have above when you first picked it up. That is quite a bucket! I know my "101" cand really lift heavy loads. Good post.
Manual says 1000lbs carrying capacity. Engine pump does fine. The boom cylinders are 2" so both together are not much more than the rockshaft cylinder.
Nick
Nick, thanks for the specs on the case loader. I have always
been curious about their capacity.
Patsy, Freeman loader looks like a nice setup on the vac as
well.
