Case W7 loader gas engine A284
I bought a old loader and someone pulled all the plug wires off. It s a case 4 cylinder gas engine A284. The firing order is on the block but where is number one on distributor? Also I keep reading that number one cylinder is the one by radiator and others say it s by the cab. If anybody has a old diagram of cylinders and plug wire locations for this old case W7 loader I have I would love a peek. I have the service manual and that s pretty vague as far as distributor goes. It s a 196? Tractor. That s all I have. Any help would be great at this point.
Number 1 is closest to the fan. If you are
facing the distributor the terminal on
your right, nearest to you is the number 1
terminal.
Thank you for the help. I found the order and she started to run. One of the valves needs a little work. I don't think this engine has run in the last 10 to 15 years. Im so happy about this tractor. I hate to see things scraped when there is still a lot to life left to them. I will run it at a slow pace for a little while before I even think about giving it a little gas. :D I have another one that is all used up and as far as parts goes thats where I will need to go for them. Thanks again
