case wheel hub pulling tool
Hello everyone. I am trying to remove the rrear cast iron wheel hubs on a Case D. There are 3 notches in the hub. I believe these notches are for the bolts that hold on a wheel weight. I am wondering if these 3 notches can be used to remove the hubs. Did Case ever offer a pulling toll for removing the wheel hubs using the same 3 notchers?
Those notches are for wheel weights I think. I have had to pull the whole axle trumpet and hub and take to a machine shop with a big press...100 ton or so. Makes the big press jump when they come loose.
Thanks Case Nutty. I was thinking of making a home made puller. But i don't think I can get 100 tons of pull out of a puller. I think I will take your advice and head to a machine shop.
Thanks again
