1070Michael
Plowing with a semi mounted plow, almost finished field and I lost all tension on the 3 point handle. It has tension back, so the arms come up but forward there is no resistance and arms don't go down. The arms loose enough pressure that if you turn off the tractor maybe 5-10 mins later they will be in the down position so I was able to get plow off, but I can't finish a field that way. My question is, Did my control cable break? If it did, is it possible to have only up working and not down working. How hard is this cable to change? Or what might it be. I'm ready to just go buy a 4 bottom drag plow, but that's not a fix. Any ideas
