case444 wireing
pappa
my case 444 has the stator(generator) behind the
flywheel. all wire diagrams i find are for
starter generator..Same engine is on my 1614
economy power king. why is it so hard to find
wiring diagrams for these tractors?
Here's a wiring diagram for Kohler engines with the stator. You should get around 30 volts AC at the rectifier on the two outer terminals with your engine at 1/2 throttle or better. Be careful where you have your hands when checking the voltage. If you have good AC voltage here check the DC voltage across your battery terminals. You should see around 14 to 14.5 volts with the engine at the speed as I described for the AC voltage. If you're only reading battery voltage of 12 volts your rectifier may be defective, but before buying a new one I would clean the DC terminal on the rectifier then check your charging voltage again. Hal
Your problem is called "Case-itis" It comes from the mistaken belief that Case still has something to do with these tractors. THEY DON'T. Parts and information all comes through Ingersoll, the company that took on the line when Case sold it off back in 1983.
The link below will take you to Ingersoll's home page. Go to the Illustrated Parts section and click on the X in the green bar that pertains to tractors without power steering. Use the serial number of your tractor to pinpoint the correct parts manual and then open it up so you an download it to your hard drive or print it out. You will find a wiring pictorial to assist you with your problem but a proper wiring diagram can be found in the Operator's Manual.
Those manuals are also specific to the serial of your tractor and can be bought from bona fide Ingersoll dealers for ten to twenty dollars. It is a must-have manual. If you e-mail me, I'll provide you with a dealer who will treat you right.
ingersoll
We both appreciate El Toro's good intentions here but the wiring diagram shown in the Kohler book is not how your Case is wired. This is why you need the correct Operator's Manual because it is very easy to make mistakes that can cause you grief. If you ruin a 40 dollar regulator/rectifier thanks to the wrong wiring diagram, the 20 dollar Op Manual will look pretty cheap at that point.
