Back on 9/22/11, Eldo case did a post titled CaseIH. A lengthy discussion and comparisons followed and is now probably lost in the weeds on page three of the Disscussion Form. j hikmper requested my list of pros and cons for my 4010 Deere.
Here is my list comparing not only my 4010 but also my recent experiences with the newer red and green tractors.
4010 PROS AND CONS
Prior to buying my used 4010, I started farming 40 years ago on a shoestring with a used 730 Case CK. Traded it for a used 930CK western special and later traded for a used 1170 with wide front and wide 20.8 rear tires. I have had the 1170 for 30 years. This 1170 with fat tires not being good for row crop, I purchased a used 400 Case O Matic for planting and cultivating. When I upgraded from 4 row to 6 row, the 400 got traded for the 4010. I was told the 10's and 20's were the greatest thing since sliced bread.
Compared to four Cases that I owned before I bought the 4010 and for the POSITIVE FEATURES , generally the 4010 steers easy, the brakes are strong and consistent. I give it good marks for being nimble. The shift pattern from 5th forward to high reverse is an inline movement of the gear shift. These things make the 4010 pleasant to operate for shuttle work, mowing in tight spots, etc. I have not had any durability issues with the 4010 but it is still a low hours tractor about 5000 hrs. The bigger 1170 and an 8830 Ford are used for the heavy grunt work so the 4010 is not worked hard.
NEGATIVE FEATURES. My very first disappointment with the 4010 was the day I drove it home from the local dealer where I bought it 20 years ago. I revved it up in road gear to my suprise 8th gear growled at me. BUMMER!!! None of the older Cases that I had previously or current owned had any powertrain noises.
Another disappointment with the 4010 was when cultivating and having to turn short at the ends, pressing hard on the brakes causes them to growl. BUMMER!!! Also, the front axle steering geometry is junk for turning sharp. The outer front tire plows a rut if the brakes are used just enough to cause the inner front tire to not skid during the turnaround. So for most cultivating turnarounds, I see crops getting uprooted by the outer front wheel plowing and also getting growled at by the brakes. DOUBLE BUMMER!!! No Case of mine has exhibited these problem.
My 4010 has a noisy hydraulic pump. It functions okay so I just endure the noise. BUMMER!!!. None of my Cases had hydraulic pump noises.
My 4010 has exhaust slobber. One has to love the Case 451 and 504 engine. My 1170 exhaust noise is as smooth as silk so this probably makes me notice the 4010's inherent, can't fixit, exhaust slobber. Exhaust slobber is caused by having the exhaust manifold's outlet located forward near the number one cylinder exhaust valve port. The 1170 has the exhaust outlet balanced midway between the front three and back three cylinders. The Case engine purrs and the 4010 engine slobbers.
My 4010 starts poorly even though the fuel injection system is not weak. In warm weather with the engine cold and quarter throttle, the 1170 fires strongly on about a cylinder's second compression stroke and one can quickly let go of the starter. For the same situation and needing at least half throttle, the 4010 has to be cranked several revolutions and then it begins to peck, peck, peck. If one keeps the starter engaged, it eventually pecks loud enough to start. The 4010's starter has been to the repair shop but the 1170 starter is still strong and never been off.
The 1170 has the more comfortable seat. I continue to be amazed at what green blood does to one's objectivity and to one's reluctance to drive a different color for a couple of days.
COMPARING THE NEWER RED AND GREEN TRACTORS
For a little background, my older brother lost much of his hearing due to running tractors without mufflers. This has made me very sensitive to what noises I allow my ears to experience. Thus, I use ear protections extensively. I even have a battery powered noise cancelation headset that removes the repetitive, reverbrating, low level, boom sounds that are generally present even in many of the newer tractor cabs. I am retired, 72, objective towards brands, and many of my farmer friends know that I can run equipment with little training and with out wrecking stuff. Therefore, I do a lot of fill in work operating the newer tractors and combines.
If I am ask to run a large, late model, row crop series, Deere tractor, I feel the need to wear my noise cancellation head set. If I am ask to run any Magnum, I feel free to leave my head set at home. Why? The later model,larger, mfwd, Deeres have a medium level, reverbrating, boom sound inside their cabs that my electronic headset helps to knocks down. Also when getting in and out of this size newer Deere, when one's unprotected ears are directly exposed to the engine, the Deere's engine idles with an ear pearcing noise. In many circumstances, tractors get use as a privacy shield to stop and take a pee. Standing close to an idling Deere really hammers the ears.
The Magnum is quieter in all respects. Being externally close to the Magnum is more pleasant to the ears and any reverbrating boom sound inside the Magnum's cab is low compared to the Deere.
The reason for the added noise in the newer Deeres has to do with a design characteristic that the 8000 and newer versions of that Deere mfwd have. The engine block is a structural member of the main frame. This makes the entire main structure of the Deere an amplifier of the engine's internal noises.
Unlike the larger Deere mfwd's, the Case Magnum uses frame rails and the engine sits on rubber mounts and thus not hard mounted to the main structure. Thus the row crop series Magnums do not have the engine's sound amplified and resinating into the cab. Being old and having to pee every hour, I can stop and pee in comfort close to the Magunum!!!!! LOL.
4010 PROS AND CONS
