Caseih part look up
Oldiron29
Is there a working caseih part look up anymore? I tried to get in as a guest got to where they as about adobe and that was as far as it would go.
Maybe real hit or miss depending on your operating system, or theirs, I don't know. Several weeks ago I couldn't make it work at all. Then just a couple weeks ago I tried looking up a NH machine/part[same site]and it worked! Maybe I caught them when they had it open for testing? Who knows?
Second on messicks. I just used their site for my new Holland. No login or anything needed to find the parts. It worked well for me.
If https://www.mycnhistore.com/us/en/caseih/login#epc::model_find doesn't work for you try https://www.mycnhistore.com/us/en/caseih/login#epc::model_find.
It works fine or maybe I will say as it is supposed to for me on a Windows 7 machine. Also on an iPhone but it is kind of rough on it because you have to switch views between the parts list and diagram. They have a little info box on it that says the updated site that shows all part numbers instead of just those available is supposed to roll out in mid December, seems we are there. In my case with a Farmall M it is easier to get to those pages then before when you had to know a work around to find it, you could find the Super M easy. The new site it comes up in the search. I will include a live link to the CaseIH Farmall M parts page, I have noticed when included as a link here it does not always take you direct to the page it only take you to the parts page home site. If you want to see all part numbers you can use a the avspare site. Just web search...avspare followed by the IH model you are looking for. Pick one of the selections in you results and when it opens find the small blue print that shows the model you are searching usually by number 4. There are a lot of adds on it so beware of those. As far as Adobe it may be you just need to update yours, if they provide a link it generally is safe to download the update. But you can never be to careful, your mileage may vary.
They changed their parts site and it’s worthless. They used to have a “my shed” that had your equipment in it and made it east. Even the parts guys at my local dealer hate it.
Ill second that..... It use to be that if the part was NLA at least you could get the Part# and google it to look for NOS!!
Now its just not listed, kinda frustrating..
All Caseih site are worthless,because they do not show all part number.If they did you could maybe find what you are looking for either used or old new stock or other places.
Marlin
yes its is bad,, but the trick to make it work is you have to select the line,, then select search by model,, then the only problem is they have deleted many pages,part listings in the older books,, was told they did it for parts no longer in the system,, yea right,, glad I have most every book from ag to CE side in paper
cnt
(quoted from post at 22:21:45 12/19/20) Is there a working caseih part look up anymore? I tried to get in as a guest got to where they as about adobe and that was as far as it would go. I found this site ! It seems to be the old case parts diagrams with part numbers has helped me a lot
[/quhttps://avspare.com/catalog/case/65617/57444/1049242/ote]
