Got my cast wheels on my A moved and set. Plowed then took the hub off painted my wheels and set them again. Took the tractor to another plow spot about three miles or so away and on the way over the right wheel walked out on the axle a few inches. What is the best way to set them things without having them move. I had light oil on the axle under the wheel and never sieze on the hub and plow coat on the exposed axle . The oil I cleaned off and the sieze I wiped most off then put the bolts to 400 ftlbs. Did I do right by getting the axle dry and the bolts real tight or am I missing something. Maybe I just didnt have them tight enough to begin with.
